Advanced guide
NetBird is open-source and can be self-hosted on your servers.
It relies on components developed by NetBird Authors Management Service, Management UI Dashboard, Signal Service, a 3rd party open-source STUN/TURN service Coturn, and an identity provider (IDP).
If you would like to learn more about the architecture please refer to the architecture section.
This guide uses the older multi-container architecture with separate management, signal, relay, and coturn containers, configured via management.json. For new deployments, the Quickstart guide uses the combined setup with a single netbird-server container and config.yaml. If you are on the older setup, see the migration guide to upgrade.
New to self-hosting? The Quickstart guide uses the built-in identity provider and is the fastest way to get started. This advanced guide is for users who need to integrate with an existing IdP or have specific enterprise requirements.
It might be a good idea to try NetBird before self-hosting on your servers. We run NetBird in the cloud, and it will take a few clicks to get started with our managed version. Check it out!
When to use this guide
Use this advanced guide if you:
- Need to integrate with an existing identity provider (Okta, Azure AD, Auth0, etc.)
- Require SCIM provisioning for user/group sync (Enterprise)
- Have compliance requirements that mandate a specific IdP
- Want full control over the authentication infrastructure
For simpler deployments, the Quickstart with embedded IdP is recommended.
Advanced self-hosting guide with a custom identity provider
Requirements
- Virtual machine offered by any cloud provider (e.g., AWS, DigitalOcean, Hetzner, Google Cloud, Azure ...).
- Any Linux OS.
- Docker Compose installed (see Install Docker Compose).
- jq installed. In most distributions usually available in the official repositories and can be installed with
sudo apt install jqorsudo yum install jq - Domain name pointing to the public IP address of your server.
- Firewall ports (see below for your setup type).
- Maybe a cup of coffee or tea :)
Port requirements
Since version 0.29, NetBird uses a consolidated port architecture where Management and Signal services share ports via HTTP/2 protocol negotiation. This significantly reduces the number of ports you need to open.
With reverse proxy (recommended):
| Port | Protocol | Description |
| 80 | TCP | HTTP (Let's Encrypt certificate validation, redirects to HTTPS) |
| 443 | TCP | HTTPS (Dashboard, Management API/gRPC, Signal gRPC, Relay WebSocket) |
| 3478 | UDP | Coturn STUN/TURN server |
Without reverse proxy (direct exposure):
| 80 | TCP | HTTP (redirects to HTTPS) |
| 443 | TCP | HTTPS (Dashboard, Management HTTP API) |
| 33073 | TCP | Management gRPC API |
| 10000 | TCP | Signal gRPC API |
| 33080 | TCP | Relay (WebSocket/QUIC) |
The default setup script configures a Traefik reverse proxy that consolidates all services behind ports 80 and 443. If you're running NetBird behind your own reverse proxy, see the advanced configuration section.
Legacy port requirements (pre-v0.29): TCP 80, 443, 33073, 10000, 33080 plus UDP 3478 and UDP 49152-65535 (Coturn TURN relay port range). If you have any clients running versions below v0.29, you must keep these legacy ports open even if your server is upgraded - older clients cannot use the consolidated ports.
For this tutorial we will be using domain demo.netbird.io which points to our Ubuntu 22.04 machine hosted at Hetzner.
Step 1: Get the latest stable NetBird code
#!/bin/bash
REPO="https://github.com/netbirdio/netbird/"
# this command will fetch the latest release e.g. v0.8.7
LATEST_TAG=$(basename $(curl -fs -o/dev/null -w %{redirect_url} ${REPO}releases/latest))
echo $LATEST_TAG
# this command will clone the latest tag
git clone --depth 1 --branch $LATEST_TAG $REPO
Then switch to the infra folder that contains docker-compose file:
cd netbird/infrastructure_files/
Step 2: Prepare configuration files
To simplify the setup we have prepared a script to substitute required properties in the docker-compose.yml.tmpl and management.json.tmpl files.
The setup.env.example file contains multiple properties that have to be filled. You need to copy the example file to setup.env before updating it.
## example file, you can copy this file to setup.env and update its values
# Dashboard domain. e.g. app.mydomain.com
NETBIRD_DOMAIN=""
# OIDC configuration e.g., https://example.eu.auth0.com/.well-known/openid-configuration
NETBIRD_AUTH_OIDC_CONFIGURATION_ENDPOINT=""
NETBIRD_AUTH_AUDIENCE=""
# e.g. netbird-client
NETBIRD_AUTH_CLIENT_ID=""
# indicates whether to use Auth0 or not: true or false
NETBIRD_USE_AUTH0="false"
NETBIRD_AUTH_DEVICE_AUTH_PROVIDER="none"
# enables Interactive SSO Login feature (Oauth 2.0 Device Authorization Flow)
NETBIRD_AUTH_DEVICE_AUTH_CLIENT_ID=""
# e.g. hello@mydomain.com
NETBIRD_LETSENCRYPT_EMAIL=""
The changes made to setup.env will not take any effect until you run configure.sh (mentioned later on).
- Set
NETBIRD_DOMAINto your domain, e.g.demo.netbird.io - Configure
NETBIRD_LETSENCRYPT_EMAILproperty. This can be any email address. Let's Encrypt will create an account while generating a new certificate.
NetBird supports automatic renewal by default when using Let's Encrypt.
If you want to setup NetBird with your own reverse-Proxy and without using the integrated letsencrypt, follow this step here instead.
Step 3: Configure Identity Provider (IDP)
NetBird supports generic OpenID (OIDC) protocol allowing integration with any IDP following the specification.
NetBird's management service integrates with some of the most popular IDP APIs, allowing the service to cache and display user names and email addresses without storing sensitive data.
Pick the one that suits your needs, follow the Standalone Setup (Advanced) section in each guide (except Google, see the note below), and continue with this guide:
Self-hosted options
- Zitadel - Previously used in the quickstart script
- Keycloak - Popular open-source IAM
- Authentik - Flexible open-source IdP
- PocketID - Lightweight self-hosted option
Managed options
- Microsoft Entra ID - Azure AD / Microsoft 365
- Google Workspace - Google accounts. Not recommended as a standalone IdP; use the Management Setup (Recommended) instead
- Okta - Enterprise SSO
- Auth0 - Flexible auth platform
- JumpCloud - Cloud directory
Each provider page includes both "Management Setup (Recommended)" (for use with the embedded IdP) and "Standalone Setup (Advanced)" sections. For this guide, follow the Standalone Setup (Advanced) section.
Google is the exception: its standalone setup is not recommended. Deploy with the Quickstart guide, which uses the embedded IdP, and add Google with the Management Setup (Recommended) section instead of continuing with this guide.
Step 4: Disable single account mode (optional)
NetBird Management service runs in a single account mode by default since version v0.10.1. Management service was creating a separate account for each registered user before v0.10.1. Single account mode ensures that all the users signing up for your self-hosted installation will join the same account/network. In most cases, this is the desired behavior.
If you want to disable the single-account mode, set --disable-single-account-mode flag in the
command section of the management service.
Step 5: Run configuration script
Make sure all the required properties set in the setup.env file and run:
./configure.sh
This will export all the properties as environment variables and generate artifacts/docker-compose.yml, artifacts/management.json and artifacts/turnserver.conf files substituting required variables.
The changes made to setup.env will not take any effect until you run configure.sh again
For detailed documentation of all configuration file options, see the Configuration Files Reference.
Step 6: Run docker compose:
cd artifacts
docker compose up -d
Step 7: Check docker logs (Optional)
cd artifacts
docker compose logs signal
docker compose logs management
docker compose logs coturn
docker compose logs relay
docker compose logs dashboard
Advanced: Running NetBird behind an existing reverse-proxy
If you already have a reverse proxy (Nginx, Caddy, etc.), you can configure NetBird to work with it instead of using the built-in Traefik.
Not all reverse proxies are supported as NetBird uses gRPC for various components. Your reverse proxy must support HTTP/2 and gRPC proxying.
New deployments: The getting-started.sh script can simplify the integration of NetBird into your existing reverse proxy setup by generating a drop-in config or bespoke instructions.
Existing deployments: Use the configuration templates on the dedicated reverse proxy page.
See the External Reverse Proxy Configuration page for:
- Complete configuration templates for Traefik, Nginx, Caddy, and Nginx Proxy Manager
- Required routing endpoints and port mappings
- Docker Compose examples for external proxies
- Troubleshooting tips
Advanced: Additional configurations for cloud providers
Hetzner
Hetzner uses stateless firewall, which means it doesn't "keep track of" whether or not an incoming packet belongs to an established connection. In this case, you may add to this server firewall an UDP port range equals to the result of:
sudo cat /proc/sys/net/ipv4/ip_local_port_range
More info can be found at this GitHub issue.
Oracle Cloud Infrastructure (OCI)
Linux images provided by Oracle Cloud includes some default firewall rules which block ingress UDP on port 3478. This is required by Coturn without which only peers in same LAN would be able to communicate with each other but not peers on different networks. Besides opening the required ports on Security Rules, you also need to run below command on the virtual machine.
sudo iptables -I INPUT -p udp -m udp --dport 3478 -j ACCEPT
Oracle Cloud discourages use of UFW. You will have to use IPTABLES.
Backup
To backup your NetBird installation, you need to copy the configuration files, and the Management service databases.
The configuration files are located in the folder where you ran the installation script. To backup, copy the files to a backup location:
cd netbird/infrastructure_files/artifacts/
mkdir backup
cp docker-compose.yml turnserver.conf management.json openid-configuration.json backup/
To save the Management service databases, you need to stop the Management service and copy the files from the store directory using a docker compose command as follows:
docker compose stop management
docker compose cp -a management:/var/lib/netbird/ backup/
docker compose start management
Upgrade
To upgrade NetBird to the latest version, you need to review the release notes for any breaking changes and follow the upgrade steps below:
- Run the backup steps described in the backup section.
- Pull the latest NetBird docker images:
cd netbird/infrastructure_files/artifacts/ docker compose pull - Restart the NetBird containers with the new images:
docker compose up -d --force-recreate
Migrating to Embedded IdP
If you've deployed NetBird using this advanced guide and want to simplify your setup by migrating to the embedded IdP:
- Your existing IdP can be added as an embedded IdP directly in the NetBird Management Dashboard
- Users can continue logging in with their existing credentials
- You can gradually transition to local user management
See the Migration Guide for detailed instructions.
Get in touch
Feel free to ping us on Slack or Discord if you have any questions
- NetBird managed version: https://app.netbird.io
