Advanced Configuration
This guide covers technical details for site-to-site connectivity, including masquerade options, access control, and troubleshooting.
Understanding Masquerade
Masquerade determines how source IP addresses are handled when traffic passes through a routing peer.
With Masquerade (Default)
The routing peer performs NAT on forwarded traffic:
- Source IP is replaced with the routing peer's NetBird IP
- Return traffic is automatically translated back
- No additional routing configuration is needed on remote networks
Device A (192.168.1.50) → Routing Peer → [Source becomes 100.64.0.10] → Remote Network
Advantages:
- Works out of the box
- No configuration needed on the remote network
- Compatible with Networks and Network Routes
Disadvantages:
- Original source IP is hidden
- Access control is limited to the routing peer level
- Audit logs show the routing peer IP, not the original device
Without Masquerade
Original source IPs are preserved:
- Traffic appears to come from the original device
- Remote network must have routes back to the source network
- Required for some compliance and auditing scenarios
Device A (192.168.1.50) → Routing Peer → [Source stays 192.168.1.50] → Remote Network
Advantages:
- Source IP preserved for auditing
- More accurate traffic analysis
- Required for certain network configurations
Disadvantages:
- Requires manual route configuration on both ends
- NetBird access control cannot restrict individual source devices
- More complex setup
Without masquerade, traffic from unknown source IPs is rejected by NetBird's policy engine. You cannot use ACL Groups or Network Resources without masquerade enabled.
Choosing the Right Approach
| Requirement | Recommended Approach |
| Simple remote access | Networks with masquerade |
| Site-to-site with access control | Network Routes with masquerade and ACL Groups |
| Audit trail needs source IPs | Network Routes without masquerade + OS firewall |
| Compliance requirements | Depends on specific requirements |
Network Routes with ACL Groups
ACL Groups provide route-level access control when using Network Routes with masquerade.
How ACL Groups Work
- Create a Network Route with an ACL Group assigned
- Create access policies that grant access to the ACL Group
- Only peers with matching policies can use the route
Configuration Example
Step 1: Create the Network Route
- Go to Network Routes
- Add a route for
192.168.100.0/24 - Select your routing peer
- Enable Masquerade
- Add ACL Group:
remote-resources
Step 2: Create Access Policies
For the route to be active, create a policy granting access to the routing peer:
Source: any-group → Destination: routing-peer-group (any protocol)
To grant access to the routed network:
Source: authorized-users → Destination: remote-resources (TCP, specific ports)
The routing peer must be accessible via a policy for the route to activate. The route itself is controlled by policies targeting the ACL Group.
Site-to-Site Configuration
Bidirectional Route Setup
Site-to-site requires routes in both directions:
Site A to Site B:
- Network Route: Site B's subnet
- Routing Peer: Site A's routing peer
- Masquerade: Enabled (recommended)
Site B to Site A:
- Network Route: Site A's subnet
- Routing Peer: Site B's routing peer
Access Policies for Site-to-Site
At minimum, routing peers need connectivity:
Source: site-a-routing-peers → Destination: site-b-routing-peers (All)
For ACL Group-controlled access:
Source: site-a-resources → Destination: site-b-resources (specific protocols)
Source: site-b-resources → Destination: site-a-resources (specific protocols)
Configuring Clientless Devices
Devices without NetBird need routes to remote networks through the local routing peer.
Linux:
# Temporary route
sudo ip route add 192.168.200.0/24 via 192.168.100.10
# Persistent route (Ubuntu/Debian with Netplan)
# Edit /etc/netplan/01-netcfg.yaml
network:
ethernets:
eth0:
routes:
- to: 192.168.200.0/24
via: 192.168.100.10
Windows (PowerShell as Administrator):
# Temporary route
route add 192.168.200.0 mask 255.255.255.0 192.168.100.10
# Persistent route
route -p add 192.168.200.0 mask 255.255.255.0 192.168.100.10
macOS:
# Temporary route
sudo route add -net 192.168.200.0/24 192.168.100.10
# Persistent routes require a launch daemon or network configuration tool
Router-level (recommended):
Configure your router to advertise routes via DHCP or add static routes for all devices on the network.
Networks vs Network Routes
| Aspect | Networks | Network Routes |
| Supported scenarios | VPN-to-Site only | All (VPN-to-Site, Site-to-VPN, Site-to-Site) |
| Access control | Per-resource policies | Per-route with ACL Groups |
| Masquerade | Always enabled | Configurable |
| Setup complexity | Simpler | More manual configuration |
| Routing peer redundancy | Built-in | Manual configuration |
| Policy requirement | Resource policies only | Routing peer + ACL Group policies |
Route Not Active
Symptoms: Peers do not see the route; netbird routes list shows nothing
Causes:
- No access policy grants access to the routing peer
- Routing peer is offline
- ACL Group has no policies granting access
Solution:
- Ensure at least one policy connects to the routing peer's group
- Verify routing peer status in the dashboard
- Check that ACL Group policies exist
Traffic Times Out
Symptoms: Ping or connections hang with no response
Causes:
- Routing peer cannot reach the destination network
- Masquerade is disabled and no return route exists
- Firewall is blocking traffic
Solution:
- Test from the routing peer:
ping <destination>directly - If masquerade is off, verify return routes are configured
- Check the OS firewall on the routing peer:
iptables -L -nor equivalent
Connection Works One Way
Symptoms: Can reach the remote site but responses do not return
Causes:
- Missing reverse route (site-to-site)
- Asymmetric policies
- Stateful firewall issues
Solution:
- Ensure routes exist in both directions
- Verify policies allow return traffic
- Check firewall state tracking
Wrong Traffic Routed
Symptoms: Unexpected traffic going through NetBird
Causes:
- Overlapping routes
- Route priority issues
- Incorrect subnet configuration
Solution:
- Review all Network Routes for overlaps
- Use more specific routes where needed
- Verify subnet CIDR notation is correct
Debugging Commands
On the routing peer:
# Check NetBird status
netbird status
# List active routes
netbird routes list
# Check system routes
ip route show
# Monitor traffic (Linux)
sudo tcpdump -i any -n host 192.168.200.50
# Check forwarding is enabled
cat /proc/sys/net/ipv4/ip_forward
On a client peer:
# Check which route is being used
netbird networks ls
# Trace the path
traceroute 192.168.200.50
Performance Considerations
Routing Peer Placement
- Place routing peers on machines with good network connectivity
- Avoid routing through bandwidth-constrained links
- Consider dedicated hardware for high-traffic scenarios
Multiple Routing Peers
For high availability or load distribution:
- Deploy multiple routing peers for the same route
- NetBird distributes traffic across available peers
- Monitor peer health and remove failed peers promptly
Monitoring
Track these metrics for routing peers:
- CPU and memory usage
- Network throughput
- Connection count
- Packet loss and latency
Use NetBird's activity logging to monitor access patterns and troubleshoot issues.
