Troubleshooting performance
A file transfer crawls, a Remote Desktop session lags, or a shared drive takes forever to open, and it is natural to reach for the newest thing in the path and assume NetBird is the cause. Usually it is worth asking two questions first, because the answer is often somewhere else. What exactly is slow? A big download behaves nothing like an interactive app or a first connection, and each points at a different cause. And where is it slow? On every peer, or only one, tells you whether to suspect NetBird at all or a single connection.
More often than not the slow part is the internet connection underneath the tunnel, how sensitive the app is to delay, or one slow hop such as a single relayed connection or one busy routing peer. This page helps you find which, before you change anything.
The path your traffic takes
Slowness can come from any hop between you and what you are reaching, so it helps to picture the whole path first. Any one of these can be the slow hop:
  1. Step 1You, at homeYour device running the NetBird client.
  2. Step 2Home routerYour router and internet provider.
  3. Step 3InternetPublic transit between networks.
  4. Step 4Office firewallThe edge of the network you are reaching.
  5. Step 5Routing peerOr the peer you connect to directly.
  6. DestinationThe resourceThe server, app, or database you want.
Every hop can be the one that slows you down. NetBird is only one of them.
NetBird is only one link in that chain. Each of the others can be the real limit: a slow home upload, a busy Wi-Fi, an office firewall that inspects traffic, an overloaded routing peer, or a resource that is simply far away.
Quick test
Two checks, about a minute, that settle most cases before you read any further:
  1. Is the connection direct? Run netbird status -d and find the slow peer. If its Connection type is Relayed, that alone explains the slowness. Fix it first with Troubleshooting relayed connections. If it is P2P, go on to the next check.
  2. Is it your network? Reconnect through a phone hotspot or a different internet connection and try the same thing again. If it is suddenly fine, the problem was your original network (Wi-Fi, router, or provider), not NetBird.
Still slow, still direct, and slow on more than one network? Then it is worth working the checklist below.
Start here
If the quick test did not settle it, work outward from your own device and stop at the first hop that explains the slowness. Each step links to its section below.
  1. Name what is slow. Throughput, responsiveness, or a one-time delay. Each has different causes.
  2. Check the connection. Is it direct or relayed, and is the reading fresh? Run netbird status -d.
  3. Measure the tunnel. Test both directions and compare to your internet plan.
  4. Narrow down the hop. Your own link, a routing peer, or the app, plus the usual traps like packet size and an inspecting firewall.
  5. Look below the tunnel. If the tunnel already matches your plan, the limit is your own connection.
  6. Rule out startup delays. A slow first connection or frequent reconnects feel like slowness but are not.
Three kinds of "slow"
Before measuring anything, work out which of these you have, because they have completely different causes:
  • Low throughput (how many megabits per second move). Big file transfers and backups drag. This is what most people mean, and it is easy to measure directly.
  • Poor responsiveness (delay, not volume). Remote Desktop (RDP), shared network drives (SMB), and accounting or ERP (enterprise resource planning) apps feel laggy even when raw speed is fine. They are sensitive to round-trip delay, not to bandwidth.
  • "Slow" that is not really speed. A long pause on the first connection, a delayed first name lookup, or an app that stalls then recovers. These are one-time or reconnect delays, not a throughput limit. See Startup and reconnect delays.
A speed test can look great while an app still feels awful, because that app is held back by delay, not by bandwidth. Keep the three apart, or you will spend time tuning the wrong thing.
Start from the connection detail. On the client, run:
netbird status -d
Find the peer you are reaching and read four things:
FieldWhat to check
Connection typeP2P means a direct connection. Relayed means traffic goes through a relay, which adds delay and shares bandwidth. Sort that out first, see Troubleshooting relayed connections.
LatencyThe round trip to the peer. High latency hurts responsiveness far more than it hurts throughput.
Last WireGuard handshakeShould be recent, and the transfer counters should move while you test. A stale handshake or frozen counters means you are reading an old snapshot.
Interface typeKernel is the efficient path on Linux. Userspace is normal on Windows and macOS, but on Linux it means kernel WireGuard is not active.
Two quick wins before digging deeper:
  • Update the client first. Throughput improvements land regularly, so reproduce the problem on the latest version before going further.
  • On Linux, check the datapath. Interface type: Userspace on Linux means the kernel WireGuard module is not loaded (a missing module, an unprivileged container, or NB_WG_KERNEL_DISABLED set). Kernel WireGuard carries less overhead, so it is worth having active. Load the module with modprobe wireguard, or see Client Environment Variables. On Windows and macOS, Userspace is expected and not something to chase.
Set a baseline with a speed test
Don't guess, measure. A short throughput test tells you what the tunnel is actually delivering. iperf3 is a small, free tool for this, with downloads and install instructions for Windows, macOS, and Linux on iperf.fr. Run it as a server on one peer and as a client on the other, both over their NetBird IPs.
# on the receiving peer (say its NetBird IP is 100.92.0.5)
iperf3 -s
# on the other peer, measure your UPLOAD to it
iperf3 -c 100.92.0.5
# add -R to measure your DOWNLOAD from it
iperf3 -c 100.92.0.5 -R
The direction matters. iperf3 -c measures your upload, and -R measures your download. Compare each to the internet plan on that side. If someone on a "300 down, 20 up" home plan sees about 20 up and 90-something down through the tunnel, the tunnel is doing its job and the plan is the ceiling, not NetBird.
Speed is not responsiveness
The speed test can report a healthy number while Remote Desktop or a file share still feels awful, because those care about delay. Run it alongside a longer ping and watch how steady it is, not just the average. Ping the peer inside the tunnel, and at the same time ping a public address outside it, so you can tell whose loss it is:
# inside the tunnel: the peer's NetBird IP
ping -c 300 100.92.0.5
# outside the tunnel: a public address, run at the same time
# (use an IP, not a name, in case DNS is going over NetBird)
ping -c 300 1.1.1.1
Look at how much the times jump around and whether any packets are lost. A low average with big swings, or any loss, makes interactive apps feel slow even when there is plenty of bandwidth. Now compare the two: if the peer inside the tunnel drops packets but the public address stays clean, the loss is on NetBird's path. If both drop, the loss is on your own connection or the wider internet, and NetBird is only carrying it. A few file-based apps (for example accounting software working on a company file over a network share) are not recommended over any VPN for this reason, and that is a limit of the app rather than of NetBird.
One caveat: a clean ping does not prove everything is fine. Ping uses a different protocol (ICMP) than your app (usually TCP or UDP), and a firewall can treat them differently, so always test the real workload too, not just ping.
Narrow down the hop
If the tunnel baseline is good but a real task is slow, find which hop owns it. Take a common setup: your client does not reach the ERP server directly, it reaches a routing peer that forwards traffic onward into the office network.
  2. Step 2Routing peer (Peer B)Advertises the office route and forwards your traffic into it.
  3. DestinationERP serverOn the office network, with no NetBird client of its own.
The client reaches the routing peer over NetBird, then the routing peer forwards traffic to the server on the office network.
  • Test the leg past the routing peer. A speed test to the routing peer's own NetBird address only measures the tunnel to it, not the traffic that continues through it to the server. From the routing peer, test straight to the server on the office network (a plain copy, or iperf3 if you can run it there). If the tunnel to the routing peer is fast but the routing peer to the server is slow, the problem is past NetBird, on the office network or the server. You often cannot install a test tool on a production server, so treat "the tunnel is fast but the real task is slow" as a strong hint the bottleneck sits past the peer.
  • The routing peer itself. We recommend a Linux routing peer running kernel WireGuard, because it carries less overhead than the alternatives. A busy machine also makes a poor routing peer: a domain controller, for example, is already doing a lot, and its other work competes with forwarding traffic. See Sizing routing peers for guidance.
  • A firewall inspecting the traffic. Many offices run a firewall that inspects traffic (deep packet inspection or intrusion prevention). Sitting between the home user and the routing peer, it can slow or stall transfers, and antivirus or endpoint protection (EDR) on the destination server can do the same. Try the transfer with that inspection temporarily set to leave the NetBird traffic alone, and see Ports & Firewalls.
  • The transfer itself. Copying thousands of small files is slow by nature, because each one has its own open-and-close, so a single large file is the fairer throughput test (on Windows, a multi-threaded copy like robocopy /MT:16 also helps). If a plain copy drags but a large file flies, the transfer was the trap, not the tunnel.
Rule out packet size (MTU)
NetBird sends conservative packet sizes by default (an MTU, the largest packet it sends, of 1280 bytes). That is deliberate, so traffic fits across almost any internet path without being chopped up. Raising it is usually the wrong fix for a remote user, because a packet bigger than the path allows gets fragmented or silently dropped, which shows up as stalls rather than a clear error. To check the path is not silently dropping large packets, run tracepath <destination>.
The opposite can help in a few cases. If transfers stall part way, or a web app shows a blank page, only on certain connections, lowering the client's packet size can clear it: netbird up --mtu 1200. For the blank-web-app case, turning off HTTP/3 (also called QUIC) in the browser is a quick way to confirm the cause.
Raising the MTU is worthwhile only inside a datacenter or cloud network where the whole path supports larger packets. That is a capacity lever for routing peers, covered in Jumbo frames in a datacenter, not a remote-access fix.
Below the tunnel
When the speed test matches the internet plan, the tunnel is not the limit. Look at the connection underneath it. The usual culprits:
  • Try a different network. The fastest way to rule out the local connection: reconnect through a phone hotspot or a different internet connection and repeat the test. If it is suddenly fine, the original network (the router, the provider, or the Wi-Fi) was the problem, not NetBird. This one check saves a lot of guessing.
  • Check whether the loss is yours. Using the two pings above, one to the peer inside the tunnel and one to a public address outside it, see whether the public address drops packets too. If it does, the loss is on your own connection or the internet, not on NetBird, and no tunnel change will fix it.
  • Home connections upload slowly. Most home plans give far less upload than download. Your upload through the tunnel, and anyone pulling data from you or through you, is limited by that small upload figure.
  • Wi-Fi versus a cable. Wi-Fi adds delay and loss that a network cable does not. Retest on a wired connection before concluding anything.
  • A saturated connection. Run a continuous ping to the peer, then start a large transfer. If the ping was steady and jumps the moment the transfer starts, the line is overloaded and queueing traffic (sometimes called bufferbloat). That is a property of the local connection, and the fix is there (a router with better queue management), not in NetBird.
Some reports are not about speed at all. They are one-time or reconnection delays that feel like a speed problem, but no amount of bandwidth fixes them:
  • A slow first name lookup. The first request to a resource by name can pause for a while as the routing peer resolves it, and some apps make it worse by remembering a failed lookup. Later requests are quick. See DNS Troubleshooting.
  • Waking an idle connection. NetBird brings a connection up when you first use it (see Lazy connections), so the very first request to a peer you have not talked to in a while can take a moment while the tunnel comes up. This is by design, and everything after it runs normally.
  • A connection that keeps reconnecting. If the link is unstable, or a laptop keeps switching between Wi-Fi and other networks, NetBird reconnects often, and each reconnect can interrupt transfers in progress. It reads as "slow and unstable" rather than steadily slow. If the client drops and comes back every few minutes, see Connection drops every few minutes. Otherwise, capture a debug bundle and reach out to support so the team can see the reconnection pattern.
Recap
The whole path, at a glance:
  1. Step 1You
  3. Step 3Internet
  6. DestinationResource
Take it one hop at a time. Decide which kind of "slow" you have, then read netbird status -d for direct or relayed, latency, and a fresh handshake. Measure the tunnel both ways and compare to your internet plan, alongside a longer ping for steadiness, plus a second ping to a public address so you know whose loss it is. If the tunnel matches the plan, it is doing its job, and the answer is below the tunnel (upload, Wi-Fi, a saturated line) or in the app. The quickest single check is to retry on a different network, like a phone hotspot. If the tunnel does not match the plan, narrow down the hop by testing the leg past the routing peer, and rule out packet size and a firewall inspecting the traffic.
Two things worth holding onto: some delay is normal when the two ends are far apart, and does not on its own mean something is wrong. And a clean ping does not prove the app's traffic is fine, because different protocols can be treated differently along the way.
Go deeper
Where the layers underneath this page are documented
Why a connection is relayed instead of direct, and how to get it back to direct.
Measured throughput per peer, the tuning levers, and jumbo frames in a datacenter.
Exit nodes
Why exit-node speed is single-tunnel and limited by the node.
Troubleshooting resource connectivity
When a service behind a routing peer is unreachable rather than slow.
Ports & Firewalls
Endpoints to allow, and how firewalls and inspection interfere.
Troubleshooting client issues
Status detail, debug bundles, and the WireGuard datapath.
