Troubleshooting relayed connections
NetBird always prefers a direct peer-to-peer (P2P) connection and falls back to a relay server when a direct path can't be established. A relayed connection works. It just adds latency and shares the relay's bandwidth, because traffic travels through an intermediary instead of flowing directly between the peers. This page teaches you to find out why a connection is relayed, fix it when it's fixable, and recognize the cases where relay is the correct outcome rather than a fault.
The endpoints on this page are for NetBird Cloud. The flow is identical for self-hosted deployments. Substitute your own Signal, STUN, and Relay endpoints from the self-hosted port requirements.
A relayed connection is just as secure as a direct one. Traffic is encrypted end to end with WireGuard before it leaves the device, and the relay only forwards packets it cannot read. The trade-off is latency and throughput, never confidentiality.
First, confirm it's relayed
On either peer, check the connection in detail:
netbird status -d
Find the peer in question and look at the Connection type field:
server-fra-1.netbird.cloud:
NetBird IP: 100.75.226.48
Public key: Mi6jtrK5To...
Connection type: Relayed
Relay server address: rels://us-nyc-2.relay.netbird.io:443
Last WireGuard handshake: 25 seconds ago
Latency: 89.5ms
| Field | What it tells you |
Connection type: Relayed | Traffic flows through a relay server instead of directly between the peers |
ICE candidate (Local/Remote) | The candidate pair ICE selected; reads -/- on a relayed connection, explained below |
Relay server address | Which relay server carries the connection |
Last WireGuard handshake | A recent handshake means the tunnel itself is healthy, relayed or not |
If the connection type is P2P but the link is slow, stop here. That's a different problem (path quality, MTU, or load), not a relay issue. Start from the general client troubleshooting page instead.
The mental model
If you remember one thing, remember this: a relayed connection is not a failure; it's the safety net after a failed hole punch. Your job is to find out which of two worlds you're in:
Why is this connection relayed?
A fixable blocker An unfixable NAT
(Signal, STUN, or UDP is (both sides scramble ports
blocked somewhere, find per destination, relay is
it and remove it) doing its designed job)
You can't ask NetBird to measure NAT behavior directly, so you work by elimination: first triage for environments that are known to defeat hole punching, then clear the fixable blockers one by one. If every check passes on both peers and the connection is still relayed, you have proven the NAT is the cause, and the relay is the designed answer, not a problem left to fix.
The four players
Four things decide whether a connection goes direct. Each one maps to exactly one check in the flow below.
NAT, the obstacle. Routers rewrite addresses, so a peer behind NAT can't receive unsolicited traffic. Most NATs hand out a predictable public address that hole punching can use; symmetric NATs and carrier-grade NAT (CGNAT) hand out a different one per destination, which defeats hole punching entirely. The theory lives in Understanding NAT and Connectivity.
Signal, the messenger. Peers exchange their candidate addresses through the Signal service (signal.netbird.io, TCP/443). If Signal is unreachable, the peers can't even compare notes, and the connection silently lands on the relay.
STUN, the mirror. A peer discovers its own public address by asking a STUN server (stun.netbird.io, UDP 80, 443, 3478, 5555). If outbound UDP to STUN is blocked, the peer never learns a public candidate and hole punching never starts.
Relay, the safety net. When no direct path works, both peers connect outbound to a relay (*.relay.netbird.io, TCP/443) and traffic flows through it, still end-to-end encrypted.
The authoritative endpoint and port list is in Ports & Firewalls.
Reading the ICE candidates
The ICE candidate (Local/Remote) field shows the candidate pair ICE selected: the addresses the tunnel actually uses. It reports successful outcomes only. If hole punching didn't complete, there is no selected pair, and the field reads -/-.
| Candidate | Meaning | Implication |
host | A local interface address | P2P over directly reachable addresses |
srflx | Server-reflexive: this side's public address, discovered via STUN | P2P; hole punching worked through this side's NAT |
prflx | Peer-reflexive: an address learned during the connectivity checks themselves | P2P; the working address surfaced mid-checks |
relay | A TURN relay allocation | Legacy fallback: appears only when a peer's connection to the NetBird relay is down and TURN carries the traffic instead |
- | No candidate selected, ICE did not complete | Expected on every relayed connection |
The mistake this field invites: reading - as "STUN is unreachable or UDP is blocked". That is one way to get here (this side never gathered a public candidate). The other is a symmetric NAT: STUN works, both sides gather srflx candidates, and the connectivity checks still fail because each NAT hands out a different port per destination, so the advertised addresses are never the ones packets actually arrive from. Both causes end in the same -/-, and both peers show it: a relayed connection never displays a good side and a bad side, so this field alone cannot tell you which network to fix. The decision flow below can.
The client log can also split the two causes directly. Raise the log level with netbird debug log level debug (or use the log inside a debug bundle) and look for the candidate and state lines:
discovered local candidate udp4 srflx 203.0.113.10:51791 ...
ICE ConnectionState has changed to Checking
ICE ConnectionState has changed to Failed
If srflx lines appear and the state still cycles from Checking to Failed, STUN discovery works and something is blocking the direct path itself: a host firewall (Step 4), an egress policy that allows UDP only to the NetBird endpoints, or a symmetric NAT. Clear the first two on both peers (Step 5) before concluding symmetric NAT (Step 1, Step 6). If no srflx lines appear at all, this side never learned its public address, so STUN or UDP is blocked: go to Step 3. A strong tell for symmetric NAT: the srflx port differs per STUN destination across those lines.
The decision flow
Work through these steps in order. Each one tells you when to continue and when to stop.
Confirm it's Relayed
1. Environment triage: are BOTH peers on known-symmetric networks?
│ yes → relay is expected, stop here
│ no / unsure
2. Control plane reachable? (Signal + Management, TCP/443)
3. STUN reachable? (Relays section of netbird status -d)
4. Host firewall in the way?
5. Repeat 2–4 on the other peer
all clean on both ends, still Relayed
└──▶ symmetric NAT proven by elimination:
relay is the designed path
Step 1: Environment triage
Some networks are known to defeat hole punching, no matter how clean the firewall config is. Before checking anything else, ask where each peer sits:
- Mobile and cellular connections: carriers use CGNAT, which usually behaves symmetrically.
- Cloud NAT gateways (AWS NAT Gateway, GCP Cloud NAT): symmetric by design for instances without a public IP.
- Enterprise firewalls in strict mode: Cisco ASA, Palo Alto, Fortinet and similar devices often default to symmetric NAT, sometimes labeled "strict NAT" in their settings.
If both peers sit on networks like these, hole punching can't succeed, and for mobile or cloud NAT no firewall tuning will change that. The relay is the expected outcome, and you can stop here (see when relay is the right answer). An enterprise firewall you control is the exception: its NAT mode is often tunable, see Corporate firewalls. If only one side is affected, or you're not sure, keep going: one predictable side is usually enough for P2P.
A CGNAT tell: the public address your network presents is in 100.64.0.0/10, a range reserved for carrier-grade NAT. Don't confuse it with your own NetBird IP. NetBird intentionally uses the same range for its overlay network, so only the address your ISP-facing connection shows counts.
Step 2: Is the control plane reachable?
If a peer can't reach the Signal service, candidates are never exchanged and the connection goes straight to relay, a common silent cause. From the peer, confirm outbound TCP/443 to both control-plane endpoints:
curl -sf https://api.netbird.io/api > /dev/null && echo "management: OK"
nc -zv signal.netbird.io 443
Both must succeed. If they don't, fix outbound TCP/443 to these endpoints first, nothing else matters until the peers can talk to the control plane.
Step 3: Is STUN reachable?
Hole punching starts with STUN, and STUN runs over UDP. The best evidence is already in netbird status -d. The Relays: section near the bottom reports reachability of every STUN and relay endpoint:
[stun:stun.netbird.io:3478] is Available
[turn:turn.netbird.io:443?transport=udp] is Unavailable, reason: allocate: all retransmissions failed
[rels://us-nyc-2.relay.netbird.io:443] is Available
Any Unavailable entry means the reported transport to that endpoint is being dropped on the path, typically by the site's egress firewall. Ask whoever runs it to allow the matching outbound traffic: UDP ports 80, 443, 3478, and 5555 to stun.netbird.io, and UDP ports 80 and 443 plus TCP ports 443 to 65535 to turn.netbird.io. The exact list and example rules are in Ports & Firewalls. If the site runs a named enterprise firewall or SASE product (Palo Alto, Fortinet, Zscaler, and so on), Corporate firewalls lists what to allow per vendor.
NetBird never needs an inbound port opened on your perimeter firewall.
Step 4: Is a host firewall in the way?
The host's own firewall or security software can block UDP before it ever leaves the machine. Telltale symptoms: peers show Connected but can't be pinged, or two peers on the same office LAN connect relayed because a host firewall drops their unsolicited direct packets. Both cases, with platform-specific checks and fixes for UFW, firewalld, and Windows Firewall, are covered in Ports & Firewalls: Host-based firewalls. If a Windows peer stays relayed, go straight to Direct connections stay relayed on Windows.
Endpoint protection software (CrowdStrike, ESET, Sophos and similar) often ships its own firewall that overrides OS rules, if connectivity works with it temporarily disabled, add an exception for the NetBird process.
Step 5: Repeat on the other peer
A connection has two ends, and both must pass steps 2–4 for hole punching to work. A perfectly clean laptop still gets a relayed connection if the server's egress firewall silently drops UDP. Run the same checks on the second peer before drawing any conclusion.
Can't shell into the far peer? Administrators can trigger a debug bundle remotely from the dashboard (Peers → select peer → Run Remote Job). See remote debug bundle generation.
Step 6: Conclude, or escalate
If every check passes on both peers and the connection is still relayed, the most likely remaining cause is a symmetric NAT in the path. A firewall that permits outbound UDP only to the NetBird service endpoints, and not to the peers' own discovered addresses, produces the same result and is worth considering. Either way, check whether it is a corporate firewall you control: many enterprise firewalls randomize the source port per destination, or scope outbound UDP too tightly, and both are tunable. Corporate firewalls has the per-vendor settings. If the NAT is outside your control (mobile, cloud, or someone else's network), accept the relay. It's the designed behavior for exactly this case, and it costs latency, not security.
If instead something looks wrong but you can't place it, collect evidence and escalate:
- A debug bundle from both peers:
netbird debug bundle --system-info - The
netbird status -doutput from both peers - The network topology: NAT device or cloud gateway, firewall vendor, ISP type
Walkthrough: converting a relayed connection
A remote engineer's laptop reaches build-server in the office, but netbird status -d on the laptop shows the connection is relayed and latency is poor. Working the flow:
- Confirm. The laptop shows
Connection type: RelayedandICE candidate (Local/Remote): -/-, like every relayed connection. The field can't say which side is the blocker, so work the flow on both peers. - Triage. The laptop is on home fiber, the server on the office LAN. Neither is mobile, CGNAT, or behind a cloud NAT gateway, so this should be fixable. Continue.
- Control plane, on the server.
curlto the Management API andnc -zv signal.netbird.io 443both succeed. - STUN, on the server. The
Relays:section shows[stun:stun.netbird.io:3478] is Unavailable, reason: stun request: context deadline exceeded. The office egress firewall is dropping outbound UDP. - Fix and verify. IT allows outbound UDP on ports 80, 443, 3478, 5555 to
stun.netbird.ioandturn.netbird.io. On the server, restart the connection withnetbird down && netbird up, then re-check from the laptop.
Connection type: P2P
ICE candidate (Local/Remote): srflx/srflx
Latency: 14.8ms
Both sides now discover their public addresses, hole punching succeeds, and traffic flows directly; latency drops from ~90 ms to ~15 ms with no relay in the path.
When relay is the right answer
Stop troubleshooting and accept the relay when:
- Both peers are on mobile/CGNAT connections. The carrier's NAT is symmetric and outside anyone's control.
- Corporate policy blocks outbound UDP and won't change. Relay over TCP/443 is the designed path through such networks.
- A cloud NAT gateway can't be re-architected. If the instance can get a public IP (an Elastic IP on AWS), that restores P2P without opening anything inbound, security groups still only need outbound rules, and the gateway's symmetric NAT drops out of the path. If it can't, relay it is.
- The NAT device belongs to someone else: a hotel, a café, a customer site.
Some teams even prefer relayed connections in locked-down networks, because the only flows leaving the perimeter are outbound TCP/443. That's a legitimate posture: the cost is latency, never confidentiality. In all of these cases, relay is NetBird working as designed, not a fault.
Guides elsewhere sometimes suggest forwarding a UDP port to a peer to force P2P past a symmetric NAT. It can work, but it gives up NetBird's core promise that you never open an inbound port on your network. Accept the relayed connection instead; carrying traffic past unfixable NATs without exposing anything is exactly what it's for. The one deliberate exception is pinning static ports for peers at sites you control, when branch firewall policy demands fixed rules; see Static peer ports for site-to-site firewall rules.
Rollout checklist
To keep a whole fleet on direct connections rather than fixing peers one at a time:
- Allow outbound UDP to the STUN and relay endpoints (
stun.netbird.io,turn.netbird.io, ports 80, 443, 3478, 5555) at every site's egress firewall. - Wildcard
*.relay.netbird.ioon TCP/443 so the relay fallback survives rotation of the geo-distributed relay pool. - Watch the
Relays:section ofnetbird status -dduring rollout, fixUnavailableentries before users report slowness. - Bake the
wt0allowance into host-firewall baselines (UFW/firewalld/Windows images), so host firewalls never silently block decrypted traffic. - Decide per site whether relay is acceptable, and document it, a deliberate relay is fine; a surprising one costs a support ticket.
Recap
In one breath: NAT is the obstacle, Signal is the messenger, STUN is the mirror, and Relay is the safety net. A relayed connection means hole punching failed, either because something fixable blocks Signal, STUN, or UDP (find it: control plane → STUN → host firewall → both ends), or because both peers sit behind symmetric NAT, which you prove by elimination. Every fix on the network is an outbound rule; nothing is ever opened on the perimeter firewall. The one inbound rule is on a peer's own host firewall, for example Windows Firewall when direct connections stay relayed. And when the NAT itself is the cause, the relay is doing exactly the job it was built for, keeping peers connected without exposing anything, with end-to-end encryption intact.
Go deeper
NAT types, hole punching, and how NetBird relay works under the hood.
Ports & Firewalls
The authoritative endpoint list, plus host-based firewall fixes.
Troubleshooting client issues
Debug bundles, log levels, and ICE-level debugging.
CLI Reference
The status and debug commands used throughout this page.
